open many files within a directory
There are times when I have a set of MP3 files within a large folder. I can select the folder to open but then have to wade through what I get to just deal with a few of the files. I know I can highlight a file (or set of files) but only one is opened within mp3tag.
Is there a way, if I select (within Windows Explorer) a set of highlighted files, mp3tag will open those files ONLY?
Is this your problem: /t/7738/1
Maybe in the past I faced your problem, too; however, I think it has been solved because I can do that now (I'm using MS Windows XP SP2).
You can get the latest version 2.45a. v2.43 still has the problem.
Only 2.45b really fixes it.
