"open with" In Wine Linux
Hi!
I' m using Mp3tag without problem with Wine 9.18 devel 64b under Ubuntu 24.04 ans Mint 22, except when I try to use "open with" in the contextual menu of linux...
If I use an old wine version (3.02 64b, with Playonlinux), there is no problem, "open with Mp3tag" opens Mp3tag in the folder where I right click.
But with the newer versions of wine, "open with Mp3tag" opens Mp3tag in the last opened folder...
I tried many things without success.
Have you a solution to this small problem??
Thank you!
And what were these?
I would try to save the configuration, un-install MP3tag, install it again as standard installation and then restore the configuration.
I tried every shortcuts, desktop entries, scripts, with all possible file path, but Mp3tag always opens the last folder opened.Only Wine 3.02 (very old version), open with playonlinux, gives a good behavior: opening the folder that I click!
A fresh install doesn' t give better result!
Thank you
