Hare Krishna.
Can I open more than one instance of the program?
I have two folders containing 1000 and 1500 files respectively and I have to compare and change the tags manually. I mp3tag cell interface allows to easily modify a tag and thus is very helpful. But when only one instance can be opened then I can use is only for one folder while in other folder I have to change through windows interface.
Thankyou,
damodara das
