The new Optimize FLAC works much more reliably & efficiently compared to the previous workaround using the downloaded tool from the FLAC website however she seems shy.
I noticed the Utils seemed to play peakaboo with me intermittently. I first assumed I must have a few hidden mp3 files in my current selection but as it turns out any selection of 41-48 files or more seems to force the Optimize FLAC option into hiding. I've spanned multiple folders that are completely FLAC and if I select over a certain number of files ...it's gone.
I tried to narrow it down to a specific number, but it varies so I cannot say that it is solely based on the number of files currently selected I was never able to select more than 48 FLAC files.
Note:
- If i selected small portions for the data I could easily get the Optimize to appear & function flawlessly
- Much of my data includes the following characters ²🅴¹🅲⁰🅸 (not sure if that matters)
- Album arts embeded are all jpg ranging from 1mb-3mb at varying resolutions
- None of the selected files have issues with holding / altering tags, skipping or other playback issues
- I am currently using V3.24a (Windows 11) but I can confirm this issue was present on the previous version although I had not tested it as thoroughly until now
