Is there any way to tell mp3tag to encode text as UTF16-BE instead of UTF16-LE? On my Nokia E51, the tags encoded as LE display incorrectly (they miss the last letter!) in the firmware's in-built media search tool. If I could force BE, it would work!
Yes, pretty much. I have a bunch of tagged mp3s that do work, and examining the files in a hex editor shows they're UTF16-LE encoded. My other mp3s that don't work are UTF16-BE encoded. Not exactly proof, but very strong empirical evidence!
Sorry - it was early in the morning To confirm, BE works; LE doesn't. This is almost certainly a problem with the Nokia firmware, not a problem in mp3tag. Anyway, I can't upload examples as they're copyrighted, but here it is in code form. Just one ID3v2 text frame:
I suspect the problem for nokia is not the byte order, but the two missing termination bytes at the end of the field (00 00)
Now the ID3v2 standard gives a little room for interpretations, but we have decided against termination byte(s)
Unfortunately nokia made the opposite decision.
I've just stumbled over codepages ....
1200 — UCS-2LE Unicode little-endian
1201 — UCS-2BE Unicode big-endian
... don't know if this is related to this topic.
