I've just re-installed mp3tag due to an HDD failure. I used to select a group of files, right click and select mp3tag from the context menu, but I cant find the option to add mp3tag to this menu in my re-installed version. Is this a feature that has been removed?
When installing it asks you if you want the shell ext. Just reinstall it and tick the box.
Can't believe I missed that.
Thanks ![]()
