I've noticed that the first thing I do every time I start the program is pressing Ctrl-D to choose target directory.
So the idea is to implement an option that will show directory chooser automatically when the program starts right before initial files scan.
This will save time that initial scan (actually useless since I will change the directory) takes. Besides will save extra Ctrl-D pressing.
In the options > general, you could set the default directory to an empty one, and tick the box "start from this directory" to save some time.
I think this work-around is a good idea, but I think the suggestion has good merit. What I find myself wishing is that there were a way to choose if mp3tag reads subdirectories upon opening for similar reasons.
