Hello All,
I have marked all the options in Further config Ape,Mpc.
Is this a good idea or not?
How do you got this section?
Hello All,
See the documentation on these settings:
Which problem do you want to solve?
Problem solved. I marked al the boxes and the problem vannished.
I only had marked, reading ID3v2, but this does'nt work, so I marked all boxes.
You do not tell us what the problem was.
Did it have to do with APE tags?
Then I would investigate which data was stored in them and whether there are other options e.g. for Replaygain.
Then I would remove the APE tags, see e.g. here:
and finally set the program that created them to stop that.
