Order of fields in the panel
I have been using Mp3tag for about a year and I keep thinking that the order of the fields in the panel on the left should match the order of the columns on the right.
"Album Artist" should be moved up below "Artist" and above "Album"
Underneath "Album" should be "Track" and "Discnumber"
Underneath those should be"Year" and "Genre"
Go to File>Options>Tag Panel (or right-click on a blank space in the tag panel). You can add or remove any editable field to display in the panel. You can also change the order of the displayed fields. You can even add separators to help distinguish sections of fields more easily.
Many thanks!
That worked perfectly for me.
