Is there a way to pad a zero and keep anything after the decimal?
This is mainly for my audio books (Been getting short stories that fit in between other main books)
SERIESNUM = 4.5
$num(%seriesnum%,2) or $num(%seriesnum%,3)
using the above will give me 04 or 004
SERIESNUM seems to be a user-defined field.
So you have to take care of its format.
the $num() function transforms a string into a number. MP3tag only deals with integers. So anything that is no number (here: the dot and following) will be cut off.
