So far I've been able to accomplish many changes with MP3Tag, what a great tool! But the last thing I'm having difficulty with is the track # in either the title or filename.
When the CD's were ripped, the track field was padded with a preceeding "0" like this; 01/21, 02/21, etc... The Title however, lists track 01 as Chapter 1, so when the list of tracks are played, Chapter 1 is played, then Chapter 11, then 12, etc... then 2, then 21, etc...
So I'm trying to figure out how to rename only the tracks with a filename (or title) ending with a 1 - 9, so that they end with a 01, 02, etc..
I found a thread talking about the function of "Formatstring: $cutLeft(%_filename%,17)" which at first I thought could modify to do what I needed, but then decided that it really wasn't the solution without a lot of additional work. Other threads didn't give me much hope either.
I could accomplish this manually, but I have about 300 tracks to modify
Instead of trying to change the filename you should build it complete new with "covert Tag-Filename".
That naturally only works, if your filename ist build of filled tags.
If you don't want to fully re/create the filename from the values of the tag fields by a fitting format string, then you may use the converter "Tag - Filename" with one format string from the following proposals ...
These format strings may remove more characters from the right edge of the filename as you want it, but I am sure, that you are able to adapt the examples to your need.
Afterwards you can concatenate the track number formatted as you wish, e. g. with a format string like ...
%_filename%''$num(%TRACK%,2)
In the event that a track number does not exist, then you may apply this format string ...
I had no idea MP3Tag was so powerful, it reminds me of when I was struggling with formulas in Excel...
I ended up combining both statements and was able to batch process large quantities of files at once.
$trimRight(%filename%,'0123456789 -.()#''')' '$num(%TRACK%,2)
