Is it possible to create a column which will show how many characters are being used per file?
Thank you.
Thank you.
Create a column with
Value: $len(%_filename%)
Leave "field" empty.
(if %_filename% is not the right property, try %_path%)
Next time, you may have to post a RTFM image as an answer to my question ![]()
Thank you for the help @ohrenkino.
