Is there any way to personalize the interface? I mean things like: making Tag panel sizable with addable or removable fields, personalize buttons in the Toolbar (I'm thinking a history button would be great)...
Well, this issue is partially solved, as I navigate through the help, I found the way to add fields to the interface. However I still need some way to add favorites directories (now, I think you can specify only one favorite), it would be great to have the possibility to specify more than one.
It's OK, but I was thinking in something more direct, something like the star that shortcut to the favorite directory, just a click, and you move to the correspondent directory.
