Picture name placeholder
Placeholders for export configurations:
%_covername% Picture name without extension
%_covername_ext% Picture name with extension
Example:
$loop(%_directory%)
%_covername_ext%
$loopend()
Returned:
What do you think about this feature request?
Is there a little bit hope that this will come alive in near future or not?
Thanks, keep such a great work
~ milka
No, this is not planned since you can use folder.jpg and so on directly in the export confiruration.
Best regards,
Florian
I was thinking of using this in if function for ex: showing if album have front or back cover, or if album does't have any covers. -_-
But it's ok, I can change the code of exported file manualy.
Thanks for answer,
--- milka
