Placeholder that can count inside "if" function
I can't get counter value inside of "if" function.
So I was wondering is it posible to write placeholder that can count (like %_counter%) inside "if" function.
Example:
$loop(%_folderpath%)
$if($eql($folderdepth(%_folderpath%),$folderdepth(%_workingpath%)),,%_counter_if%)
$loopend
Please reply Florian, thanks
~ milka
What exactly are you trying to achieve?
Already possible:
$loop(%_folderpath%)$puts(cnt,$if($eql($folderdepth(%_folderpath%),$folderdepth(%_workingpath%)),$get(cnt),$add($get(cnt),1)))
$loopend()
$get(cnt)
Thanks dano, but I dont think that thats it.
I dont wont to get max counter, I just wont to count inside "if" function.
I will test it when I came home.
What is "$get(cnt)"?
~ milka
cnt is a user defined variable that I declared with $puts (see scripting help file)
And please write want.
Sorry. :blush: My english is bad.
You don't have to bother with this, because it's hard to do or even impossible.
I was just trying to help to HankD.
~ milka
I make it, thanks again dano.
I just nedded to put $get(cnt) inside of loop.
$get(cnt)
$loopend()
Best regards,
~ milka
