Is there a way to add a column that shows how many times I've played a song?
Thanks
If your player supports the POPM ID3v2 frame and updates it correctly, you might want to try the POPULARIMETER field.
Kind regards,
Florian
If you use Zune, popularimeter frame is used to rate the song as like or dislike.
