I want to export playlists only.
The tracks are always sorted in order of the filenames.
How can I let mp3tag export by using the order, given by the playlist?
Simply change $loop(%_filename%) to $loop(%artist%) or whatever you wish.
yeah, that´s clear.
but what is the code for random play order?
I load a playlist -> files are listed in mp3Tag as they are in the playlist.
-> I want this order in the exported file.
Which variable do I have to use?
Try $loop(%_path%)
works. thanks a lot.
$loop(%_total_files%) also works.
