Please Help me with the question below - remove number
Help requested please
Tags shown: File name and Title (example)
(there are no spaces between 1.Lights)
Editors - 1.lights 1.lights
This should be like this:
Editors - Lights Lights
The 1 stands for number 1 of course, but also applies to all the other songs on the album
Thank you very much in advance! Elie
Try Convert>Tag-Tag or an action of the type "Format value" for TITLE:
Format string: $regexp(%title%,\d\.,)
Maybe the slightly enhanced format string
$regexp(%title%,\d+\.,)
would be a better fit, especially if the OP has numbers with two or more digits like in the example:
Editors - 10.lights 100.lights
The \d+\. would replace any number of digits followed by a dot, with "nothing" = remove them.
Thank you very much for the quick and beneficial answer.Thanks to you my problem has been solved and that is of course fantastic, I am very grateful! Elie.
