I've got some lyrics files formatted like this.
[00:12.161]Hey, that shark has pretty teeth, dear
[00:18.822]And he shows 'em, pearly white
[00:24.680]Just a jack knife has MacHeath, dear
[00:31.349]And he keeps it way out of sight
[00:37.453]When that shark bites with his teeth, dear
[00:43.837]Scarlet billows they begin to spread
[00:49.966]Fancy white gloves has MacHeath, dear
[00:56.359]So there's never, never a trace of red
I want to turn e.g.
[00:12.161]
into
[00:12.16]
Is there a way to have a filter show only the tracks that have these lyrics with the seconds to 3 decimal places instead of 2?
So I'm trying to look for any track that has .xxx] in &unsyncedlyrics% (xxx stands for any three numbers).
I've already worked out how to remove that 10th chartacter with Actions>Action (Quick)>Replace with regular expression>
Regular expression: ^(.{9}).
Replace matches with: $1
which is great. But I can't work out how to find all the tracks that need fixing.
I feel it's probably possible, having seen this page, especially this example:
Filenames that start with two digits not followed by another digit:
%_filename% MATCHES ^\d\d\D
But I can't work out how to find tracks that have .xxx] in &unsyncedlyrics%
Very grateful if you can help. Thanks.
