Pmedia tag removal
Hi Everyone,
Is there a way I can easily remove all instances from every tag contains the characters "PMEDIA"? For example, a typical mp3 I obtained has PMEDIA in many of the typically unseen tags like ISRC, Uploader, and release country. I also would like to remove all of the instances of tags that contain the expression pmedia, but are not limited to just those letters. An example would be this odd expression
eng||www.t.me/pmedia_music which is found in the very odd unsynchedlyrics field. Just out of curiosity, what do the two upward bars (which is found with the backward slash key) do? Seems suspicious to me.
or
Telegram: Contact @pmedia_music found populating the Lyricist field.
Thanks for your time and help !
Ed
This is interesting.....
When I typed and posted the following on the thread I just started
Lryricist field contains this---- Telegram: Contact @pmedia_music it read in the chat viewer and was posted as
Hmmm.......makes me wonder what is actually happening.
Maybe following the process found here:
With tracks selected right mouse click. Choose the to Extended Tags. Eliminate the tags you want. Save your choices. Voila
@joeleger This would remove all the selected tags from all your selected tracks. Not only the ones with PMEDIA inside a specific tag.
You need to find the tracks with the tag containing PMEDIA first. Then you can use your steps.
Otherwise you delete content from tags that you want to keep (content that could be something else then PMEDIA).
As @ohrenkino wrote more then 10 years ago in the above linked thread, please use a Filter (F3) first:
and enter PMEDIA to show only tracks with PMEDIA somewhere in your tags.
