Polish translation missing strings
As of Mp3tag v2.93a, these are the untranslated strings for the Polish translation of Mp3tag.
/cc @burtek in case you want to help out
_C_ABORTING Aborting...
_C_CANCELING Canceling...
_C_MNU_VIEW_FILTER_AUTOAPPLY Auto-apply filter
_C_OPT_ADVANCED_LISTCHAPTERS List chapters as separate files
_C_OPT_GEN_CHK_KEEPMOVEDFILES Keep moved files in file list
_C_OPT_LIB Library
_C_OPT_LIB_CHK_ENABLE Enable Library
_C_OPT_LIB_CHK_RESTRICT Only include these directories
_C_OPT_LIB_CLEANUP Cleanup Library
_C_WIZARD_TRACKS_DESC Assign track- and discnumbers
_C_WIZARD_TRACKS_DISC_BEGIN Begin at discnumber
_C_WIZARD_TRACKS_DISC_LEADINGZEROS Leading zeros for discnumbers (01, 02, ...)
_C_WIZARD_TRACKS_DISC_SAVETOTAL Save total count of discs
_C_WIZARD_TRACKS_DISCNUMBER Discnumber
_C_WIZARD_TRACKS_TRACKNUMBER Tracknumber
_M_STR_CUSTOMIZE Customize...
_M_STR_DEFAULTVALUE Default value
_M_STR_FIELDSIZE Size of field
_M_STR_FIELDROWS Rows
_M_STR_SB_CLEANUPDATABASE Processing files ... {1} of {2} ({3} cleaned)
_M_STR_SB_CLEANUPDATABASE_BINARIES Cleanup orphaned binaries
_M_STR_SB_CLEANUPDATABASE_COVERS Cleanup orphaned covers
_M_STR_SB_CLEANUPDATABASE_NONLIBFILES Cleanup non-library files
_M_STR_SIZE_LARGE Large
_M_STR_SIZE_MEDIUM Medium
_M_STR_SIZE_NORMAL Normal
_M_STR_SIZE_SMALLER Smaller
_M_STR_SIZE_SMALL Small
_M_STR_UPDATE_OPT_CHECK_RELEASENOTES Display release notes for new versions
Sure! I'll post it in 2-3 hours :slight_smile:
Hi all!
Here is my try.
I provided some translations for CLEANUPDATABASE entries, but all 4 are not 100% understandable for me. I can't find these texts in the wild, can you point me to them in the application?
What "binaries" do mean, could it be just "data"?
Does "Cleanup non-library files" mean "Delete files entries that has moved or was deleted from Library folders"?
Additionally:
  1. in Actions: "Case conversion" = "Schreibweise aendern" = "Zmień pisownię"
  2. in Help > About Mp3tag:
    "Credits" = "Podziękowania"
    "Donate" = "Donacja"
    "Support" = "Wsparcie (ang.)" (ang. - abbr. from "english")
