system
January 26, 2007, 11:00pm
1
So I extrated all the files from the install EXE, but its still not using default directory and still CREATING its individual files inside documents and settings. Please make it read stuff from the directory its sitting in!
Or just provide simple portable alternative download
THanks!
dano
January 27, 2007, 11:03am
2
You have to place the file mp3tag.cfg in the directory of Mp3tag.exe
Some detailed description is available at portablefreeware.com
system
January 28, 2007, 4:55pm
4
ah thank you...this could have been explained better in the readme, but now I asked thank you!!
As long as it doesn't try to write anywhere else on the harddrive besides its directory i'll be fine..
thanksagain
system
February 18, 2007, 5:54am
5
Every start an Mp3Tagerror.log is created in root directory with this message:
Mp3tag v2.37a - 17.02.2007 - 22:53:01
OS-Version: Windows XP Service Pack 2 (Build 2600)
Build: Nov 5 2006 11:32:21
AppPath: 14.377.848.832 Bytes frei (D:\Downloads\!Tools\)
DataPath: 14.377.848.832 Bytes frei (D:\Downloads\!Tools\data\)
TempPath: 47.111.086.080 Bytes frei (C:\DOCUME~1\****\LOCALS~1\Temp\Mp3tag v2.37a\)
