Quote:
"If you want to backup your settings, please choose File, Save configuration. To restore the backup, you have to unzip the backup archive to %APPDATA%\Mp3tag which usually expands to the following directories
Windows XP
C:\Documents and Settings\<username>\Application Data\Mp3tag
Windows Vista
C:\Users\<username>\AppData\Roaming\Mp3tag
Windows 7/8/8.1/10
Note: If you use a portable installation, just use the program directory to store the settings
End Quote:
Please explain the underlined sentence above. I have not (yet) created a portable installation on a USB memory stick, but your instructions to create it seem straightforward. However this last sentence doesn not make any sense to me. Can you help?
Thanks...
Dennis...aka "d2b"
