Since this is very confusing, I'll change it to the next release and will ignore any existent registry keys.
Best regards,
Florian
Best regards,
Florian
But doesn't that mean that first time upgrades (from reg to cfg) won't have their settings converted?
I think disabling registry writing would be best.
how many settings do you have?
they are easliy handled (I think)
its the actins, mte and tools that I hate trying to synch between computers.
Uhm, how about simply copying the data and export directories?
yup thats what I do. currently but if I could have the whoel thing on my usb stick it would make me happy.
most of the oterh aps U use for ripping are comand line or portable.
then when I reate a new command / action It just goes with me.
ir whn I share the program with firends I can jsut send a zip file and not tell them put this in this directory and this in this direcotry...
The latest Development Build should work on an USB stick without problems now.
Best regards,
Florian
awsome
it even installs withthe cfg file under the program directory.
thanks
Has anyone else tried this method and found it sufficient - to make a portable Mp3Tag installation?
Thanks.
Please make a new topic.
