Portable mp3 Player with ID3v2.4 UTF-8 Support
does anybody know (or own) a portable mp3 player
which supports displaying ID3v2.4 tags with UTF-8 Unicode encoding ?
The two iAudio (Korean company) players I know (i5 and X5)
do not :frowning:. Anybody knows whether iRiver players support them
properly, for example ?
Cheers!
Klaas
PS: If, for any reason, you wanna try whether your portable supports them make
sure that there are no v1 tags in the files, because it might display them instead if
it doesn't find a v2 Tag :smiley:
