Possibility to sort covers by size
Hello, I have little experience with MP3 Tag. Could you please tell me if the program has a function for sorting covers by their size?
Do you ask for columns showing the width and height or the size in Bytes?
The Value for the first column is:
[%_cover_width% x %_cover_height%]
The Value for the second column is:
%_cover_size%
I just realized that you are a new user, therefore, here is the link to the detailed documentation about the customization of columns in the File List of Mp3tag:
You can sort by any column using the menu View -> "Sort by" entries or by clicking on the respective column header (toggles: ascending/descending sort order).
Yes, this is exactly what I needed. Thank you so much!
As a new user: Please check the solution by clicking on the :check_box_with_check: tick icon on the comment.
This also marks your question as "solved". Thank you.
