Hello,
as you know MusicBrainz has also cover image, the resolution may vary, sometime 1200x1200, sometime 360x360.
Would it be possible to save cover always e.g. 600x600 in Mp3Tag despite the resolution in MusicBrainz?
Thank you & regards
MM
Hello,
Thank you & regards
MM
You can use an Action after the import of your MusicBrainz image to resize it to the size you want:
Directly saving in a new resolution during the import is currently not possible.
And BTW:
You can not enlarge a small 360x360 picture to a bigger 600x600 image.
You can only reduce a bigger picture to a smaller one.
