Possible to Convert FLAC to ALAC or MP3 with Mp3Tag?
Curious if it's possible to convert the actual file format. I'm appreciative of any help in advance!
-J
No, MP3tag is a tagger for the tag data, not for the audio data.
You would need a different program for format conversions.
But you can somewhat integrate them with Mp3tag by using the
File > Options > Tools
feature, where you can add piece of software to which you can send files straight from selections done in Mp3tag
I myself have counterparts of those Tools in my file manager FreeCommander, which makes it quick and convenient to convert my files
@Zerow look no further than foobar2000
Scripted file renaming (much like mp3tag) the way you'll like it too!
:slight_smile:
Don't be intimidated by the "command line encoders" bit. I'm pretty sure it's all available as "plugins" which you just copy into the program folder (e.g. ./plugins/flacEnoder.dll ; ./plugins/lame.exe ; etc) which you would get from that same web site, and .zip extract as desired.
