Possible to filter on bitrate?
Can't find bitrate in the filter field list. I'm sure there must be a way. Can anyone help me out?
Thanks to Florian for the great program!
Try "BPM".
No, BPM is something else, you cannot use the filter on the bitrate.
But you can sort by bitrate.
When I sort by bitrate, the order chnages, but not in ascending or descending by bit rate, can anyone help?
You can have a look at the bitrate column configuration via View > Columns.... Please make sure that that everything except Value is empty and the Numeric checkbox is enabled.
Best regards,
Florian
Got it working, Thanks!
