I would like to assign random track numbers to a collection of tracks; is that possible? So is I have 100 tracks in view, I would like those tracks to be numbered from 1-100, but not as a result of sorting by time or alphabetically or other characteristics.
See View>Columns>Sort by .. random.
When you use the Auto Numbering Wizard (Ctrl-K), it applies track numbers in the order displayed on screen. So if you use ohrenkino's advice on how to randomize your tracks, then apply Ctrl-K, you will have... random track numbers!
I don't know what the OP wants to do with that random order.
You could also save the randomized sequence in a playlist so that you do not have to modify the field TRACK ...
Thank you very much; the answer was right in front of me.
