I just started using this program for almost 2months and I was wondering if there is a way to block Windows Media Player from creating that hidden file "folder.jpg" which is the album art...
Here's my situation...
I have about 201 mp3 files in the same folder. I edited their tags and the cover art...but somehow, WMP seems to reveal "hidden tags"... I experimented again and again until I finally solved this problem...I moved all files to another folder, deleted all hidden covers in the folder, cleared the history of WMP, deleted the cache in the Windows folder and I managed to fix it...
The problem is, I still can't fix the album art problem... Whenever I play a music, minutes later, it would create a hidden "folder.jpg". Sometimes, that "folder.jpg" is not a problem at all... but often, whenever I play another mp3 which is of the different album art, the art displayed doesn't change...
My conclusion? All the album art WMP creates is named folder.jpg which means, if I play an mp3 with a different art, it would borrow the existing folder.jpg instead of creating a new one because it is not possible to have the same filename inside a folder...
Now, does anyone know how to solve this problem? or know how to prevent WMP from creating "folder.jpg"? or if possible, knows how to make WMP overwrite an existing folder.jpg everytime I play an mp3 with a different cover art? And is it possible to rename the cover art name from folder.jpg to different one?
Though I'm not quite sure my conclusion is correct... but I don't see any other reasons about that cover art problem...
