I've belatedly finally upgraded from Windows 10 Pro 1803 to 1809. All appeared to go well but I now have an annoying problem when ripping CDs to FLAC files. I'm honestly not sure whether this has anything to do with MP3Tag but I'm hoping the collective wisdom of this community can point me in the right direction. I've searched the net but can't find others with a similar issue.
So far I've managed to exclude WMP and a couple of plug-ins as the problem by ripping a CD with another program (Goldwave V6.36) and then sorting out all of the tags with MP3Tag (V2.94). The tags all appear fine from within MP3Tag but when the resulting files are viewed with file explorer two of the fields (Title and Contributing Artists) are limited to about 25 characters. If I then start WMP 12 it updates my carefully set tags for these fields to the first 25 or 26 characters only. I hadn't expected it but WMP is obviously not the problem as it occurs even when WMP is not running.
Could I have set something wrong or allowed a default to be reset by the Windows update?
I'm more or less out of ideas and at my wits end. Any thoughts welcome.
