Hello guys
Somehow and suddenly I get a strange behavior, which I can't solve. When I run mp3tag I create a NFO file with notepad.
In the NFO this line is present:
$loop($num(%discnumber%,3)$num(%track%,2)%_path%)$num(%track%,2)'. '$left($replace(%title%,'Å','Aa','å','aa','a°','a','Æ','Ae','æ','ae','Ø','Oe','ø','oe')$repeat($char(32),57),57)' : '[$replace(%length%,'',':')]
$loopend()
I have added this: 'a°','a', cause suddenly it changes å too a°, which should be aa.
Can anyone help?
The NFO file is saved in ANSI, if that has anything to say.
Is that just some kind of shortcut in the description? I am sure that you cannot run MP3tag code in notepad.
Could you give an example string?
Because when I use the $replace() statement in the Converter>Tag-Tag for test purposes (preview), it replaces an awful lot of characters but I am not sure that this is what you want.
I don't see a problem with the format string. Can you double-check if the actual audio file contains the right characters?
Kind regards
– Florian
This is what it generates:
TRACKLiSTiNG
01. Lys I Din Lejlighed : 04:05
02. I Mine Oejne : 04:16
03. Falder : 03:09
04. Mer' End Kaerlighed : 04:11
05. Millionaer : 04:29
06. Vi Lever : 04:31
07. Igen I Dag : 04:09
08. Nangijala : 03:55
09. Ringe I Vandet : 03:30
10. Vover Pa° At Ga° : 03:54
11. Sirenerne : 04:26
12. Under Stjernerne Pa° Himlen : 02:54
PLAYTiME..........: 00:47:29
TOTAL SiZE........: 328,20 MB
Lets take song number 10, filename is:
110-Vover På At Gå
You're replacing in the TITLE field in your export configuration, not the filename. Can you double-check the contents of the TITLE field for track 10?
Kind regards
– Florian
My bad.
This is title:
Vover På At Gå
It works as expected here. Have you tried saving the export configuration as UTF-8?
Kind regards
– Florian
Still the same. Weird. But don't think there is much to do. It's only that 1 album, so I can live with it.
Thank though.
http://imgur.com/a/Xw3Gc
