Choosing select all does nothing. ??
It should select all what's in the text field / file list that has the focus right now.
Can you check again? If it does indeed nothing, I'd need a little bit more information on how to reproduce the issue.
They are all mp3's. Of course whatever file I was editing is focused. Go to edit, select all, doesn't select any. I can click, hold shift and click to select however many I choose.
Weird it just worked. Didn't yesterday, very weird. If I run into the problem again, I'll post. Thanks.
