Excellent, that worked great. While I was renaming that album (Requiem for a Dream), I found another problem. All the tracks have a colon ( in the track name, so when I go to rename them via "Tag - Filename", it'll say there are illegal characters in the filename. I tried adding a rule to the "Standard" Actions (in the Convert menu) to replace ":" with " -" in the _FILENAME variable, but that didn't help. Is it not possible to run those Actions when doing "Tag - Filename"?
