I meant that may be I should have used specific setup in mp3tag, nothing else.
Some texts in greek are ok other are not. For greek texts I first typed them with http://www.lexilogos.com/clavier/ellenika.htm since I do not have a greek keyboard then copied and pastes..
for "...du Bouddha d’émeraude.." it's in french and i just used my keyboard. the problem was with "é"
In both cases the problem is with the "title" fied, no problem with the lyrics field.
The correct data are shown in Mp3tag but not if I change the setup with "ID3v2.3 ISO-8859-1 " in that case I get "??????????????????????????????????"
The following applies only to MP3 files. Other file format may have other encodings.
I would suggest the following:
Create a new column to show the character encoding. For this enter
as Value: %_id3v2_character_encoding%
This should ideally show UTF16
If it does not, then use an action for these files: "Convert code page": https://docs.mp3tag.de/actions/convert-codepage
After that, it may be necessary, to re-enter the data.
Something similar can be achieved with the program "Mp3diags" that shows you if and where there are files with strange encodings and it even allows you to correct it.
Data corruption is possible as the original data cannot be determined any more.
