Hi, I have been using Mp3tag on my Windows PC for a good while and have never had a problem with it, until now. It appears I have accidentally installed version 3.19 of the 32-bit version and version 3.18 of the 64-bit version. I want to update to version 3.23 of the 64-bit version.
When I try to install version 3.23, I am told an existing 32-bit installation has been found that needs to be uninstalled.
If I go into Settings/Apps & features, the version that is shown is the 64-bit version, which I don't want to uninstall (don't want to lose the config, but I don't appear to have the option to retain it).
If I go into C:\Program Files (x86)\Mp3tag and run Mp3tagUninstall.exe, I am told to close Mp3tag, but it isn't running! Consequently, I can't uninstall this version.
Any ideas? Thanks
