Hi all. Even though I am absolutely a newby I have been using MP3tag without any pproblem so far. Kudos to the author
However now I am suddenly having a problem I can't figure out.
I have new MP3 files to which I want to add a cover art to. I do this using the extended tags dialog. The dialog does not show any cover art to start with, but when I add one it will list on top of the cover art (Cover 2/2). Why is this? There was no cover to start with.
I have also added a Covers column to the the main window and correctly it shows 1 even though I can't see any when I open the extend tags dialog.
Does anybody have a clue of how I get rid of this invisible cover?
My files contains only ID3v2.3. I have selected the options to remove ID3v1 and APE tags and selcted the remove tags command (just in case there were any).
Any help is appreciated.
Thanks.
Alessandro
