Problems with exporting
I tried to export the files, but it didnt work. I got the [ SYNTAX ERROR IN FORMATTING STRING ] message although i chose the html standard style. What did I do wrong? Please help. It used to work before ;_;
I'm using the 2.30 version. I also have a problem installing the newest version.
Thanks.
Go to your Mp3tag Installation directory, like C:\Program Files\Mp3tag
Then copy the *.mte files in the export folder to this folder:
%appdata%\Mp3tag\export
and replace old files.
If you have troubles with installation try redownloading the Mp3tag.exe file.
Thanks! It works. :w00t:
