Program no longer opens ANYTHING
Program worked perfectly for years...Now if I try to open a folder or drag and drop a file into it it shows NOTHING. So I can't see or alter any tag whatsoever.
Perhaps you have the filter turned on. What happens if you press F3 to toggle the filter?
Did you check the statusbar to see how many files are loaded and how many are displayed?
