Program starts but selected folder contents are not displayed
Just installed v 3.28/64bit on W11 Pro on an AMD Ryzen 5 5600U with Radeon Graphics. Previous version 3.27a worked fine. This one does not display anything in the contents 'part' of the screen. The loading indicator flashes momentarily and then it just stops. Most of the menus are grayed out ofcourse.
What gives?
Thank you for your time and generocity! This program has helped me a lot!
Do you have the Filter enabled? You can check by pressing F3 and see if the files reappear.
Greetings! Sorry for wasting your time... It was that simple...
Thank you very much!
