I just set up to add the "Publisher " Field succefully, and is also showing in the main window in column view
but...
The entries in the "publisher " field don't appear in the main window.
I can see it in the field where I can change the name, but it's not showing in the main window.
Hopefully I'm being clear enough
let's say I have an mp3... I check the tag with winamp, and in the publisher, the label name "Kompakt" is written.
When I launch mp3tag, and look in the big main window where all files are show, I have a column named "publisher", but it is blank... when I select the file.... I see on the left, where I can input all the infos, in the Publisher field, the name "Kompakt" is shown (in this peculiar example) it could be any other label name....
