Question about setting track number based on MP3 creation date
Hi all - thanks in advance for any help!
Is it possible to set track order of a group of MP3s based on their creation date? For example, track #1 as the MP3 with the oldest creation date of the group, and track #2 as the MP3 with the second oldest creation date, and so on.
Hopefully, that makes sense. Thanks again!
You can add a new column to the File List via Preferences β†’ File List that displays the creation date using %_file_create_datetime% as value and %_file_create_datetime_raw% as sort criteria.
Clicking on the header of this new column in the File List sorts the files accordingly (alternatively: View β†’ Sort by β†’ Created).
After that, you can use Convert β†’ Assign Track Numbers... to sequentially assign track numbers in one go.
It worked! Thank you so much Florian!
