Question about Tag
I have 2 Questions about Tags
  1. What does it mean if in the Tag column is standing
ID3v2.3 (ID3v1 LyricsID3v2 ID3v2.3 APEv2)
does this mean i have all these tag's hanging on the file?
ID3v2.3
ID3v1
LyricsID3v2
ID3v2.3
APEv2
  1. How do i get rid of LyricsID3v2 & APEv2 Tag ?
Thank You
gotit
  1. Yes
  2. You have to enable ID3v1 and APEv2 at Options > Tags > Mpeg > Remove and remove the tags via [Ctrl+R]
It worked ... the problem was i didn't know that Ctrl + R will remove the tag.
Thank you so much ...
