Quick actions replace
i have loads of music files i wish to alter example below
BB56_02 - Guy Mitchell - Singing The Blues
how can i remove the BB56_02 - using quick actions
there are many files all numeric that i want to alter all at the same time ie as a batch
is there anyway to do this
TIA
Rob
Is that the filename?
You could use Convert>Filename-Filename
Mask over old filename: %1 - %2 - %3
Mask over new filename: %2 - %3
