Can we have a update where it would be possible to save your tags by pressing enter instead of having to move the mouse to that tiny blue save button? It would make the editing much much quicker and as far as I know pressing enter does nothing while you are editing the tags. At least can we have the option to turn on in settings that enter saves the tags. Thank you so much!!
Ctrl-S does the same.
Having Enter as trigger to save would make it difficult to edit multi-line fields like the one for lyrics or comment.
