Rar Files Metadata Wont Apply
Hello
I Recently Downloaded Some Rar Files Went Thru The Tag Steps With Information Of Songs ETC. It Shows It When I Open MP3Tag But Doesn`t Show The Changes In The Actual Folder? When I Do The Same With A Zip File NO Issues At All?
Any Ideas?
Thank You
Anthony
I don't really understand.
Is it that you edit a file while it is still in a rar-archive?
The I would say it is a problem of the OS that supplied the file.
Perhaps the support for zip-archives is better than for rar-archives.
I would suggest that you unpack the archive, edit the files and then pack them again.
