So I've been using ratings in my files. I actually apply the rating in the .mp3 file itself in Win Explorer (right click > properties > details > Rating).
That's a star rating (* to *****).
I was using the %rating wmp% column in the main window - which shows as an integer (from 1 to 5).
But, for some reason, that's stopped working? I can see the Star rating in Win Explorer, but, it doesn't show (as an integer from 1 to 5) in MP3Tag main window anymore? Anyone have any ideas on this?
No.
You could have a look at the extended tags dialogue (Alt-T) and see if you find a field there that could contain the rating.
Yet, if you rated mp4 files with the WE then you will not see the rating in MP3tag as the WE stores the data in an incompatible way.
