http://bugzilla.songbirdnest.com/show_bug.cgi?id=9084
After 1.1.1, Songbird is able to write Rating into tag.
it uses "TXXX:rating", and value range: 0-5.
Would Mp3tag support this soon?
It's already supported (though a POPM frame would be the right place for storing this information in ID3v2 -- which is also supported by Mp3tag).
Just have a look at the extended tags dialog [Alt+T] and add a new column to the file list via View > Columns... or a new field to the Tag Panel via Options > Tag Panel.
Thanks for replying.
Songbird Reads TXXX:rating, but Mp3tag writes TXXX:RATING.
And values entered should be limit in 0-5.
A kludgy solution:
Add the new field "Rating" to the tag panel, find the file %APPDATA%\Mp3tag\data\usrfields.ini and edit the value=RATING line to read value=rating.
Careful when editing – this file seems to be UTF-8 encoded, with a BOM. Use an appropriate editor.
If you now enter/modify the rating value only via the tag panel at the left, never with the column view editor, you’ll succeed writing TXXX:rating tags…
Then again, you might cry out loud at the Songbird forums and ask them to support POPM! It’s of no use if everybody invent their own tags.
I can only support this.
Especially, differentiating between rating and RATING will result in a number of different problems. Additionally, it's very unlikely that one single application out there will support an input restriction on a user-defined frame.
