Ratings column
Hi, great product.
Just wondering about ratings (stars out of 5)
WMP11 gives you the option of 'Maintain my star ratings as global ratings in files'. (File -> Options, Library tab)
When I was looking for an ID3 tagger, I came across Tag&Rename, which showed found these ratings
Her's a screenshot of the two
:slight_smile:
Thanks
Load a file and press ALT+T or :mt_tag: to have all tag fields listed. Mp3tag does not display the rating with stars, though.
You can create a column like in my screenshot.
You can find the full strings here.
Once you have this column, you can enter 1 to 5 * chars to rate the song.
But it might not really work with WMP since it has a little different scale and a different identifier.
(An action could be used to make the rating WMP compatible afterwards.)
